need some info on changing wheels
Old 12-17-12, 01:35 PM
jbone29
jbone29's Avatar
Default need some info on changing wheels
currently i have 18x8 in front and 18x9.5 in rear. if i go back to stock wheels can i still use the same tires? being the stock rear is a 18x8.5. is it safe to go from a tire perspective to go down an inch?
Old 12-17-12, 01:49 PM
KillaIS250
KillaIS250's Avatar
What size tires are you running right now tho that you plan on reusing on the stock wheels?
Old 12-17-12, 03:49 PM
Uda880
Uda880's Avatar
Since tires generally can stretch and fit a wide range of width. Such as, if you have a Hankook V12 255/40/18, and since they fit widths from 8.5" - 10", you would be fine if you went back to a stock 18"x8.5" wheel.
http://www.tirerack.com/tires/tires....10XL&tab=Sizes
Old 12-17-12, 04:51 PM
Slammer1
Slammer1's Avatar
Impossible to say, without knowing what size tires you are currently running....
Old 12-18-12, 06:17 AM
jbone29
jbone29's Avatar
hankook 255/40-18 in the rear.
ExplorerII
01-08-19 02:43 PM
smakee
GX - 1st Gen (2003-2009)
01-05-15 12:25 PM
mulasien
10-14-14 05:29 PM
garroids
03-18-14 03:54 PM
sc430aloha
Wheels, Tires & Brakes Forum
07-30-11 09:45 AM
Quick Reply: need some info on changing wheels
