"JDM" Side Markers
Old 12-18-12, 08:17 AM
Kumar350
Kumar350's Avatar
Yes if you can it would greatly appreciated
Old 12-18-12, 08:18 AM
rookieIS
rookieIS's Avatar
might want to check with Nigel (vendor)
Old 12-18-12, 08:22 AM
koksik
koksik's Avatar
leave it with me, I try find out as quick is possible
Old 12-18-12, 10:37 AM
GiantsFan
GiantsFan's Avatar
My friend John has sidemarkers on his ISF ... I like the look
ISCjonny
ISCjonny's Avatar
couple of the US members have done this already in the past...
requires a precision hole to be cut on the fender since the jdm turn signal housing only allows about 2mm allowance before the hole can be seen outside of the edge.
do a search and you can find some old posts regarding this.
im pretty sure i have another set laying around somewhere at home.
i had them on my is350 sedan before.. If i remember correctly the location was either 14.5" or 16.5" from the bottom of the fender and 3" from the side.. and i believe the "JDM" way is to angle the sidemarker to follow the lines of the car.
You gonna need a dremel, steady hands, and a lot of patience. GL
Old 12-18-12, 10:48 AM
Vroomin350
Vroomin350's Avatar
beautiful car
Old 12-18-12, 10:53 AM
Kumar350
Kumar350's Avatar
Where did he get them? Did he do the install his self?
Old 12-18-12, 11:06 AM
B16da9
B16da9's Avatar
Originally Posted by o7iS250
x2 for the side marker install, I would also love to know. And the headlight ordeal looks like it's just a sticker... bake your headlights so you can break the silicone seal and slap a sticker on there, that's my best guess lol
very easy to do with a relay and some extra wiring.
Also the wiring of the sidemarkers is cake, I personaly have them on my Integra and wired them up as parking lights and turn signals.
Old 12-18-12, 12:50 PM
Kumar350
Kumar350's Avatar
I wan to wire it up to my puddle lamps and parking lights not rele indicatior but if i can get all 3 why not
Old 12-18-12, 02:22 PM
Sffd103
Fire Slayer
Sffd103's Avatar
L-tunedparts.com used to sell them. They come from overseas if you have a connection. Ill Mike had them on his candy pink 350 and then his grey. Isuxel had them on his white 350 as well.
Attached Thumbnails "JDM" Side Markers-ill-mike-2.jpg   "JDM" Side Markers-isuxel-rolling-shot.jpg   "JDM" Side Markers-ill-mike-1.jpg
Old 12-18-12, 03:56 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
These can be ordered from your local dealer.
81730-30131 (Qty: 2, Both sides are the same)
Jeff
Old 12-18-12, 05:24 PM
don
don's Avatar
I thought 2IS's don't exist in Japan? Or am I just horribly mistaken? (It wouldn't be the first time)
Old 12-18-12, 06:10 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
You are quite horribly mistaken.
Jeff
Old 12-19-12, 03:47 AM
gerill2p
gerill2p's Avatar
They sell them in ebay
Old 12-19-12, 05:27 AM
azndriver
azndriver's Avatar
06-08 Type: 81730-30131 (Qty: 2, Both sides are the same)
09-13 Type: 81730-53020 RH, 81740-53020 LH
Jeff
Thats neat..
is there are style difference between the two seeing that it is two different years you listed?
Quick Reply: "JDM" Side Markers
