Confused... DRL Issue, I'm probably just a moron
So today a coworker pointed out I had a light out. When I got home a few minutes ago, I checked it out and found this...
![](http://i900.photobucket.com/albums/ac201/HiImBrandonnn/photo-5-1_zpsd79637c5.jpg)
After browsing some threads I discovered that DRL's can only be turned off by a Lexus/Toyota dealer or the bulbs have to be removed and when that happens the high beams don't work. Well my high beams work and now I have a random light out. Is this a parking light? Pics...
![](http://i900.photobucket.com/albums/ac201/HiImBrandonnn/photo-6-1_zps69446202.jpg)
![](http://i900.photobucket.com/albums/ac201/HiImBrandonnn/photo-7-1_zpsae197a6d.jpg)
DRLs are the same bulbs as high beams. Through relays, the bulbs are wired in series when running in DRL mode. So, if both of your high beam bulbs work, then the problem would in the relays that wire the bulbs in series (very unlikely). To me, it looks like the pass. side high beam bulb is burnt. keep us posted.
I actually switch them with Philips Ultinon 6000K T10 to match the Ultinon 6000K D4S on the car (note the pics above was before I switched to Philips!!).
Nigel-JDMParts has them. He is also a CL-Forum vendor so he's safe.
http://www.nigel-jdmparts.com/Philip...5w-ultinon-led
Yes your park light is out. I just replaced my parklights with LEDs. The park lights have a cover to protect it from dust and moisture and the driver side cover is a tight squeeze to get your hand in. you have to remove the windshield washer cap holder off.
I found the Philips Ultinon 6000K D4S with Ultinon 6000K Parking lights.
Hi all,
I finally installed Philips Ultinon 6000K Parking lights and Philips Diamond Vision 5000K Headlights and Fog Halogens. What do you think?
Philips Ultinon 6000K Parking Lights on only. Note, since it's taken with flash, the HID appears on, but is only the reflection of the flash.
![](http://img688.imageshack.us/img688/2490/img0638hi.jpg)
Philips Ultinon 6000K HID and Parking Lights + Philips Diamond Vision 5000K Fog Halogens.
![](http://img688.imageshack.us/img688/9319/img0648q.jpg)
Philips Ultinon 6000K HID and Parking Lights + Philips Diamond Vision 5000K Headlights (High beam).
![](http://img851.imageshack.us/img851/1286/img0658s.jpg)
Yes, that's your parking light. Easily accessible and swappable.
Pop in a good set of SMD LED 168 series bulbs and be done with it.
$13 shipped for the same bulbs as sold elsewhere for $30+ and they match perfect with 6000k HIDs.. http://cgi.ebay.com/ws/eBayISAPI.dll...m=200864106613
![](http://i900.photobucket.com/albums/ac201/HiImBrandonnn/photo-8_zps474a2323.jpg)
Side note: Can't wait to go lower, I think I'm going to order my coils Monday or on Christmas!
Appreciate that link man, I may grab them now. The $30-$40 I was seeing was making me think I'd just leave them off. Took the one that was good out so I'm not lopsided now. Haha.
