Help! Question about fitting my wheel
I'm thinking to get a new set to wheel but having trouble finding the right set up.
I'm looking to get 19x8.5 +30mm front and 19x9.5 +35mm rear. My car is running stock suspension and will these wheel fit without any fender mod? I like the flush look and also what size of tires should I get? Thank you everyone.
The rear offset at +35 will be fine. Front with 8.5 width at +30 will rub against the fender liner even without drop. Stock height may not run into any problems with front fender tab, however, if your wheels are silver, at that offset, it will accentuate the wheel gap.
