Bumpy Ride
Are you running "V" rated tires? A higher speed rated tire will give you a stiffer ride, as the sidewall of the tire is stronger. Higher speed rated tires are stiffer and give better performance in regards to cornering and handling but the sacrifice is ride quality. A higher speed rated tire will will handle better but be a rougher ride.
Loop up some hankook ventus v12.
My ride was bad on some einter 17s previous owner had one. When i switched to summers it was the same thing.
I swear to god my car drives smoother now on low pro 19's V12s.
A bit stffer due to h&r springs but generally a smoother ride on stock suspension even though theyre 235/35 265/30
Thanks SL222.
I've been messing with the air pressure in the tires since yesterday and I'm getting some mixed, yet expected results. Too much air, even a little, the car got pretty floaty. I've been stepping down since and the ride was ever so slightly better but not good enough.
I scheduled in some service time with Lexus on Monday morning since it's free to have it looked at just in case (sanity check). Will report back if everything looks OK or perhaps they find something.
