mark levinson amp output wattages per channel
Old 02-02-13, 04:56 PM
vapid2323
vapid2323's Avatar
Originally Posted by Gville350
While on the subject of the ML sub. what specifically fails on these things for them to "blow"? Has anyone thought about replacing an ML sub with a non-ML sub?
Just had mine fixed, seems like a simple fix most can do at home, take a look (sorry for the bad pics)
Attached Thumbnails mark levinson amp output wattages per channel-picsplay_1359844798934.jpg   mark levinson amp output wattages per channel-picsplay_1359844764010.jpg
Old 02-05-13, 07:43 PM
fng
fng's Avatar
What is it that was fixed?
Old 02-18-13, 03:25 PM
pmiller
pmiller's Avatar
Originally Posted by fng
Thanks, I would rather replace it if I could, just to save the down time but if not I will probably go your route. Did everything work fine without the subwoofer while it was out for repair?
Is that for US models? Why does everyone think it's 12-ohm?
Anyone know the wattage for 2010 LS? What about the wattage of the amp? Can it produce more wattage than the speakers?
Old 04-11-13, 11:04 AM
vapid2323
vapid2323's Avatar
They jumped the spider with the two wires.
Old 04-22-13, 02:49 PM
LexoRoller
LexoRoller's Avatar
What do you mean, jumped the spider?
Old 04-22-13, 02:55 PM
vapid2323
vapid2323's Avatar
The spider is the bumpy part that you see below the two wires in the picture above. The ML sub is designed slightly different from the picture below but you get the idea.
As to the fix, the power normally ran directly along the spider, that connection burned out, so they take the new wires and attach them to each end and make sure it has enough slack to move with the subwoofer.
donaldp
07-20-21 11:16 AM
a1rh3adsz
11-10-17 12:44 PM
Robles84
07-10-15 02:13 PM
Xanadu350
07-06-13 02:25 PM
Bocatrip
03-08-12 03:47 PM
Quick Reply: mark levinson amp output wattages per channel
