Late oil change?
That is totally fine. There's absolutely 0 reason to worry. A lot of people go longer between oil changes here and have 0 issues. Even if you go a thousand miles extra on regular oil, you aren't going to run into any trouble unless your oil is physically low. If you use synthetic, there are members here that have done 10k+ intervals without issues.
i commend you for your concern , if more people had your attitude, i think there would be a lot of better condition used cars out there.
but like others have said, you are perfectly fine unless you are low on oil or something.
You should always check your oil dipstick regularly in case your engine is burning oil, excessively dirty, etc. You can probably drive thousands more miles if you wanted to, but regular oil changes is always good.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thank man
Me agreed !! hahaha
Thanks again ya'll!!
