Bad Idea? GFX front + Vertex sides + JP Vizage rear
Old 01-08-13, 11:53 AM
peyman
peyman's Avatar
Default Bad Idea? GFX front + Vertex sides + JP Vizage rear
I already have the GFX front because it's my favorite
recently have falling in love with the JP Vizage rear
and i think Vertex has the cleanest / best looking side skirts
issue could be parts not lining up right, recently lowered my car and its slightly raked (front being lower then rear) so i think the the lining up part might be close to be perfect with gfx and vertex sides, just not sure how sides and rear will flow together
bad idea? or good idea? any thoughts? anyone ever see this mixup? anyone got pics?
1st pic jp vizage rear in case some havent seen it
2nd pic vertex sides
3rd gfx in case some havent seen
Attached Thumbnails Bad Idea? GFX front + Vertex sides + JP Vizage rear-20120602_161007.jpg   Bad Idea? GFX front + Vertex sides + JP Vizage rear-3977796809_ed3a4bf962_b.jpg   Bad Idea? GFX front + Vertex sides + JP Vizage rear-68a982ab.jpg
Old 01-08-13, 12:04 PM
bob4256
bob4256's Avatar
Ive never seen that setup before but normally mixing different parts of different kits together doesnt flow
Old 01-08-13, 12:12 PM
iRyan
iRyan's Avatar
i don't think so at all...too much confusion and different height levels on each piece
Old 01-08-13, 12:21 PM
peyman
peyman's Avatar
look at the vertex sides, it doesnt even line up with the vertex front lip. it really SEEMS like gfx front & vertex will line up fine or better than the vertex sides/front
i duno it seems like even the rear would line up close to perfect w/ jp vizage rear
the only issue i see here is vertex sides being too clean/simple looking vs jp vizage got too much design and thats what might throw off the look
Old 01-08-13, 12:51 PM
str8hust1a
str8hust1a's Avatar
why not just get gfx sides?....
Old 01-08-13, 12:52 PM
peyman
peyman's Avatar
bcz its hardly a upgrade to the oem skirts. plus i want the jp vizage rear, which i dont think gfx sides would come close to lining up with.
Old 01-08-13, 12:59 PM
str8hust1a
str8hust1a's Avatar
i have the gfx sides, they are not the same as oem.. lower and better looking.
Old 01-08-13, 01:03 PM
reyoasian
reyoasian's Avatar
won't flow
jp rear too aggressive for the gfx front
vertex sides hang lower than gfx front
Old 01-08-13, 01:05 PM
Vroomin350
Vroomin350's Avatar
I had the vertex sides and they hung too low even for the Fsport front lips. It wouldn't look good with the GFX front. I would look into Toms sides, they are like vertex but hang a little higher.
Old 01-08-13, 02:23 PM
juvi22003
juvi22003's Avatar
No bad idea, please dont....
Old 01-08-13, 02:39 PM
don
don's Avatar
I don't see anything wrong with GFX and JP Vizage.............
Old 01-08-13, 02:43 PM
rookieIS
rookieIS's Avatar
it doesn't flow imo.
Old 01-08-13, 02:58 PM
JDKane527
JDKane527's Avatar
5-axis front + vertex sides is what Javy used to have. He rounded it out with an INGS rear, so that worked nicely.
GFX front and JP Vizage by itself would be good, Tom's sides like someone else mentioned would be good in between if it looked blank.
Tom's sides and rear with GFX front would look nice. If you want to stick with the JP Vizage rear, I'd imagine the 5-axis front with vertex or tom's sides would be pretty slick.
212LeX
212LeX's Avatar
Do you still have the sides?
I'm liking the vertex sides better than the tom's because if its looking hangs lower and should flush with the front and rear kit i have on but vertex soooo expensive...
Old 01-08-13, 03:05 PM
jsmacks
jsmacks's Avatar
Not all that bad..
Vertex rep sides $320/pair - http://nextmod.com/webstore/index.ph...oduct_id=30788
Quick Reply: Bad Idea? GFX front + Vertex sides + JP Vizage rear
