HELP front fenders rubbing
Dude... He never said he couldn't afford to fix fitment issues... gtfo your high horse... He's asking for help thats all. If you don't have anything positive to say just leave it be. This forum is a place we all go to look for help. We all have one thing in common and that is modding our cars whether it be a poormans build or your baller build... Jesus.
im running 10.5 wide +15 up front and slightly tucking tires 225/35. rolled and slight pulled fenders and i rub, theres no way around it. running 215 tires might help a little. hey projectdna i got legit rims (enkies rpf1s) why do i still rub?
"dude", you must've also missed my first post in this thread where i told him what he needed to do.
now get off your high horse.
there's actually one main fundamental problem causing your fitment issues - i'll get to that later, btw - so i actually tracked down where heyarms and i gave you VERY useful advice for your fitment needs (that you obviously didn't follow):
and because you didn't bother to read those two posts in their entirety, here's another follow-up post just a few posts later.
see where the fundamental problem is? it's not with what heyarms and i posted, but it's really a simple issue of you not reading and paying attention to the advice given. you've missed so many details that your issues are being caused by the same things heyarms and i told you to watch out for.
you thank 2slixx for coming to your aid and sticking up for you, yet i can't find anywhere in his thread where he's actually offering any real help.
on the other hand, i give you some actual useable advice - twice, now, actually - and a heavy dose of common sens... and i'm the bad guy.
hey, you're welcome.
you got 10.5's +15's up front. you're going to really need to pull your fenders more.
That's the thing. If I bought real rims now then what money would I have left on fixing the issue? I just wanted to try it out on cl cos I know there is alot of people here that are helpful. That is why I choose to get replica so I know what is there to fix and still have money on the side just in case I gotta do anything. Then when I get everything solved all I gotta do is save up money for vip modular and I'm good to go. I rather spend less on rims for now and have money on the side than 5+ grand on rims and be ****** up with everything and have no money on the side. But anyways thanks for the help.
225/35-19 + 245/35-19
rolled + naturally pulled fenders, modified fender tabs, deleted fender tab bolt
go with higher spring rates if you haven't already ordered your coilovers. megan EZ's standard spring rates are not condusive to lowered ride heights + wide/low offset wheels.
reading is fundamental. really.
you'll also need to shave down the rear fender tabs.
as far as a pull is concerned...
btw, bolded and enlarged for emphasis, in case you didn't catch it the first time around.
First off bro it's not the spring rates I have a problem. IT'S THE RUBBING ISSUE WHEN I TURN THE WHEELS! And secondly I don't have problem about my rears just the fronts. If you read the info I gave in the first page you would know that I did cut off and rolled whatever I needed too. So you need to start reading more. And lastly I did thank you for the help! So idk what's your problem. I didn't come here to fight with somebody online cos I got better things in life than doing immature things. I just came here for help. Thats the reason why on the TITLE IT SAYS HELP!
Now now MEN.....lets take it easy here now. Ok, advise was given and now heard. Lets leave it at that big anyone else has any other helpful info then that's fine but let's keep the back and forth to a minimum please.
Ok i lied, I'm running the same wheel but a 19x9.5 +12 offset only to clear the 350 caliper. Yes its the plastic tab that bolts the fender to bumper. I got rid of my splash guard a while back and didnt notice any problems after. An easy solution to fix this is to get a front camber kit and add more negative camber. A bit unsafe because you will effectively reduce contact patch but hey hella flush right? lol
ive just put on S1R Meisters 18x9 18x10 +22 all round and mine do the same.
Fine on the rears, rub on the plastic liner at the front.
Im just going to cruise around for a while to wear a groove into them and then see how it goes from there, any more rubbing i.e: bumper tab etc etc i will look at rectifying that problem but for now, im just going to enjoy my car knowing its only a thin bit of plastic rubbing away at a tyre thats not going to cause much harm
Hey bro goodluck on whatever you decide to do to fix this problem. I am also having the same problem and It sounds like metal on metal.
Whatever you do, please document and take pics to upload in this thread what you did so others can find it helpful later on down the road when this question comes back up again.
https://www.clublexus.com/forums/is-...c-fenders.html
Hey sr20mofo, would you happen to have any pics of your set up??
honestly the way your fender look they are going to end up cracking how mines did. I had the same prob but i was running 225/35/19 at 22 offset with federal tires which run a size bigger. The only thing to do is to lift up the car half an inch in the front and if not put 215 and best of luck. i took my fender liner off and i also know the noise you're saying only thing to do is to lift it up a little.
