Anyone else have the issue where they turn on air or heater and the mode is autmatically set to the floor? I think my friend jacked it up whenhe changed my air filter... Issue started to occur after this change. Mode will switch when I manually change it. Any help would be great thanks.
Did your friend put the car into recirculate mode before changing the filter? If not, chances are the system was broken. It's a common mistake people make when changing the filter.
Isn't it normal with the AC on heat, it uses feet vents?
