Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
#183
The other thing to consider is that this is my daily and its slammed on bags. I'd say I go WOT about once or twice a month. I really love it for the added torque and mid-range. As long as i don't blow something up on the dyno, it should be fine.
#189
So, I'm wondering, were (or are) you running around 50/50 water/meth? If not, what mix? Also how much water/meth to fuel were you running? I see recommended from about 10-15 percent.
Thx
Thx
#191
I don't know if you question was directed at me or not, but I was asking about the ratio of water/meth to FUEL not fuel to air. So 10% to 15% water/meth, 85%-90% fuel is the ratio I see used a lot. But I've seen some say you could go as high as 25%
#192
50/50 water/meth is a pretty standard ratio. Its the highest mix you can get that is non-flammable. Depending on applications, like on a high boost EVO, I'm sure you have to be more careful with it. Methanol will affect your tune.
#193
50/50 answers the question of water to meth. I am also interested in how much (water/meth) to fuel you were using.
As in
I have read 10% water to fuel (if injecting water only)
Up to 25% water/meth to fuel (with 50/50 water/meth)
So I was wondering how much you were injecting, given that it sounds like you are using a 50/50 water/meth formula.
So have you found your leak? How is the boost controller/headers/cogged pulley working out?
Thx
As in
Thx
#194
As in
Thx
As in
Thx
