Re-Installing Stock Airbox & Intake, Help!
2006 IS350
So I removed my K&N Typhoon intake and noticed that I seem to be missing a couple of screws (or so I think).
Can anyone confirm that the bottom half of the stock airbox is screwed down in two spots? There are two protruding extensions that line up with holes on the chassis. However, I can't seem to find any screws in the diagram that I linked below so I am at a loss as to whether or not screws were ever used there.
Also, I can't seem to recall what the clips on the hose portion of the intake are for. I am referring to part #23841-31040.
If possible could anyone take a photo of their stock intake setup for reference? I am having trouble finding anything that focuses on the airbox itself.
I am selling the car and am worried about the intake rattling around. If anyone knows the dimensions of the screws let me know, I'll just go buy it at a hardware store.
http://is.sewellparts.com/images/oem...000/174532.jpg
Thanks!
Thanks!
Yes there are two screws that hold down the bottom portion of the airbox. One on the passneger fender side and one behind the passenger headlight. I think the clips are to hold some of the wires that go near the intake.
In a pinch (if you're trading it in) just throw some welding putty on top of it. Once it hardens it won't go anywhere. A small amount of welding putty will go a long way.
I am only recommending this since you're trading the car in AND if you can't find the bolt size you need.
Good luck.
Good luck.
I needed to check my air filter anyways so here is a couple pictures of the stock intake. I didnt realize how dirty it gets even with the engine bay covers on- Time to clean!
