Nav issues after buying new IS
Hey guys,
I have used the NAV in my old 2006 IS350 plenty of times, I have driven cross country (WA to NY) and back so I am quite apt with changing regions etc.
Anyhow this new 2011 IS350 seems to have issues with addresses, in fact I have tried about 10 or so addresses and it can never find the site. I checked that I am in the proper region and all that but its still having a hard time. Also the addresses are not new, most of them have been around for at least 5 years.
Any ideas? Why is this new nav missing all the addresses I had back on my 2006?
wa= washington? if so how did you go about updating its location. how long ago did you buy this car like 2 days ago? a week ago?
did you manualy update its location or did you let the car sit outside so that it located its self on the navigation.
So it has nothing to do with the GPS its just changing the database the car looks at when your entering an address.
Like I said, I have used the nav in my old car for over 6 years, I just wanted to check here first to see if I can do anything more to troubleshoot
I bought the car about a week back now, so 6-7 days..
its cool im just eliminating possible causes for your issue. try this first before anything drastic.
you can skip this step if you need.
(Refer to the “Lexus Bluetooth® Compatibility Information” link on the Technical Information
System (Diagnostics>Telematics), to verify phone compatability.
Connect the phone to the vehicle via Bluetooth®. Follow the steps outlined in the “Quick Pairing”
instructions on TIS.)
try this step for sure.
Open the Enform App on the phone.
Press the "MENU" button.
Select "Info/Apps".
Select "Apps".
A screen indicating “Checking for updates” will
be displayed.
The screen will indicate if the App update is
required or optional. Press the "OK" button to
proceed with the update. If NO update is required,
the APP Suite screen will appear (Figure 9).
A screen will appear indicating the update is in
process.
Select “OK” once the Apps update is complete.
Select "Info/Apps".
Select "Apps".
be displayed.
process.
those steps were straight from lexus technical information system.
if that doesnt work you need to see if there is an issue with rewriting the nav info onto your system.
Lexus tech*
Lexus tech*
Select "Info/Apps".
Select "Apps".
be displayed.
process.
Select "Info/Apps".
Select "Apps".
be displayed.
process.
I've learned along the way that if you switch searching option by "Address" and "City", it may work. For example if you searched by choosing address first, and if it does not exist, try using "City" first. I found that it worked for me lots of times.
