Oil Filter Part Number
Quick question, what's the part number at toyota/lexus for the oil filter and washer ring we need to replace for our oil change?
Tried the search engine but couldn't find it and I called Lexus and they were reluctant to give me the information... And Toyota says that they do not contain any Lexus information at their dealership.
by the way, that's the only thing we need for an oil change other than the oil and tools itself right?
Same washers different filters... They have very little compatible filters. Reguardless of same motor we have difderent filters.
But d1= g1
A1=a1
A3= .....
A6=a6
A4=a4
A5=a5
If you drive an is250 its an a3 but if its awd its an a5 and tell them you take 6.6 quarts of oil 6.8 awd And tell them resetting the maintenance light is the same as their push.start toyotas. Press odo, Hold the reset toggle through power button, wait for 5 bars to go away
But d1= g1
A1=a1
A3= .....
A6=a6
A4=a4
A5=a5
04152-YZZA3 is for RWD models, 04152-YZZA5 is for AWD models. 90430-12031 is the drain plug washer/gasket.
The filter element itself is the same, as is the large o-ring, the A5 includes an extra smaller o-ring and a drain hose adapter. You can use either filter if you have a RWD model. A Toyota dealer should have the A5 filter (it's used for the FJ Cruiser and 4Runner), but the A3 isn't used in an Toyota models in North America, so they may not stock it.
Jeff
Jeff
NikonGuy
12-20-14 03:15 PM
stlgrym3
06-23-11 11:34 PM
