How do you take out chrome emblem on stock grill?
Old 02-09-13, 12:10 PM
NormandyIS
NormandyIS's Avatar
Default How do you take out chrome emblem on stock grill?
Im switching my grill and i want to re-use my chrome emblem however what is the best way to remove it?
thanks
Old 02-09-13, 04:36 PM
itsivan
itsivan's Avatar
thanks
Cut thru the glue with a razor you could also try with tooth floss
Old 02-09-13, 05:31 PM
jbjones85
jbjones85's Avatar
what itsivan said.. you can also you a plastic putty knife to wedge under there and pry it off. Just be careful. The emblem has two alignment "tabs" that help align it so be careful not to crack those off as you pry the emblem off. They are are at the 3 and 9 o'clock position (i think).
Old 02-12-13, 06:48 PM
Initial G
Initial G's Avatar
I would use a razor and gently trim the double sided tape/glue that attaches the emblem to the grille. Dental floss helps as well. Make sure to carefully clean the emblem before reinstalling it.
Old 02-13-13, 01:17 AM
SCWB
SCWB's Avatar
I bought a new "L emblem when I swapped my F-Sport. The new emblem is not expensive. I don't want to risk breaking the old emblem nor the grill surrounding it, if I have to remove it.
Old 02-13-13, 05:14 AM
iRyan
iRyan's Avatar
man just yank that think off lol...naw be very careful not to crack then end...use a finish line if you have one or some floss
Old 02-13-13, 05:49 AM
bob4256
bob4256's Avatar
What everyone said will work. You can also use a hairdryer to help you out
Old 02-13-13, 11:55 AM
NorCalIS
NorCalIS's Avatar
^^^^This, or a heat gun, literally just pulled mine off two days ago. Heated up the back a good amount on high with the heat gun, then went over the front on low, stuck a knife in between and started turning... Came out like butter. Make sure you start with the pins on either side to prevent them from breaking.
k311in
General Classifieds
02-05-18 09:06 AM
gekae24
10-16-15 10:01 PM
onslaught
11-30-09 09:39 AM
dangy
07-25-09 05:18 PM
kalristo
16
02-26-08 08:43 AM
Quick Reply: How do you take out chrome emblem on stock grill?
