Check VSC, HELP!
On the right side of your engine bay, under the large plastic cover, you'll find your fuse box. It will be the box all the way to the right with a cover on it that can be removed by hand. After removing the cover you'll notice a diagram outlining all of the fuses in the box. Pull the 10 amp ECTS fuse (red) located upper middle, and the 25 amp EFI fuse (white), located lower middle for a few minutes.
There's a fuse puller in there to use too
^Cool didnt know that...
Now mine turned on when I was pulling fuses from inside the car when I installed the 2011 LED Tails... the right side one didnt want to turn on and after a few days apparently the Amperage was set on the ecu and they worked correctly.. I had even went to a friends dad that is an electro-mechanic and hadnt found anything wrong.. and voila they were fully functional all by themselves..
