SOS my is250 battery keeps draining
Old 02-17-13, 05:28 PM
whitebeast
whitebeast's Avatar
Do you have any sound system in your car?
Old 02-17-13, 05:35 PM
whitebeast
whitebeast's Avatar
check it out. Hope it help you
Old 02-17-13, 06:29 PM
Chase2910
Chase2910's Avatar
http://www.youtube.com/watch?v=zdIKNnwEjIs
Thanks, I watched the video I will go find a multi meter to test with, when I went to Lexus they did a drain test they said the amps were normal would that be the same thing or this is different, sorry kinda a noob lol
Old 02-21-13, 05:50 PM
Chase2910
Chase2910's Avatar
jus an update, id like to thank everyone who helped, my batt went dead again so i took it back to the dealership they kept it overnight, basically did exactly what the video above said ( checked all fuses to identify drain ) they found it was coming from the alternator ( i didnt know the alternator could drain battery but ...), so i have had it replaced, i will update this thread if the problem comes back again
thanks again to all those who commented your input was appreiciated
Old 07-12-13, 03:48 AM
RichardDin
RichardDin's Avatar
My Lexus 250 IS has the problem starting the car in the morning, the battery seems drained, and I need to reset the reverse camera setting each morning. The battery was replace in Novemer 2013. I have taken the car to have the battery tested, no fault was found with the battery, however the car had a 1 Amp leakage with all system turned off. I was told is could by the tracking system. The tracking company replaced the tracking system, as it was older than 5 years, and these satellite tracking system can cause problems after 5 years. This still has not solved my problem. If the car stands for 2 days I need to jump start it. I had had the computer plug into the car to test it. It was testing with the ignition on and with the engine running. No fault found.
Old 07-20-13, 07:31 AM
Chase2910
Chase2910's Avatar
Try watch the video above, if you can do it you might get your answer, when I took my car to Lexus they did the exact same thing
coldplay24
10-28-17 01:20 PM
docsccs
05-21-17 05:12 PM
tradosauru
06-20-16 03:18 PM
jackblack7
10-12-13 12:06 PM
Skrapp
01-19-13 03:03 PM
Quick Reply: SOS my is250 battery keeps draining
