SOS my is250 battery keeps draining
Hi guys, I have an 2008 is250 a few moths ago my battery started draining, I thought it was lights or something so I turned all inside lights off , including trunk, still persisted. Went to get it checked at Toyota they said battery so I got a new one
Problem came. Back a month later went back they did tests they say everything is fine so I decide to take the car to Lexus on the park ( Toronto ) they do their tests they can't find the problem, charge is fine, battery tests ok, they can't find irregular drain, today it is empty again
PLEASE HELP
PLEASE HELP
Hello,
I had the same problem and I'm still waiting to hear back from Lexus Canada. I had a battery replaced on January 25,2013 and it was dead on February 9th, 2013. I was told my starter and alternator were fine and unable to find any external battery draws.
Once is hear something I will post on the forum. Good luck, if you purchased your battery at Toyota/Lexus they come with an 84 month pro-rated warranty; I realize this does not accommodate for your time
Chris
Chris
thanks all
yes i got a new battery from lexus and they say its not the battery they tested everything with no luck
every time i go they charge the battery for me then it last about 2 weeks then same problem comes back
Hello,
Chris
Chris
Thanks that sounds like a plan, just to make sure we on the same page u saying the night before I pull a fuse if it does the same thing I keep trying different fuses overnight until I find the problem
I also thought it was my alternator so when I went to Lexus and they checked the system I specifically asked them about that and they said the charge system is fine, alternator is OK
