HID going out?
No need to post in both is and gs forums...
https://www.clublexus.com/forums/is-...going-out.html
As a matter of fact u should just post it in the lighting section!
Definitely sounds like a bulb going out. It's an easy enough replacement. When my left HID bulb was on its way out, it would randomly turn off after a few minutes of driving with the headlights on. It happened once, and didn't happen for over a week, then started doing it every couple of days. Each time, turning the lights off and back on would restore it. I bought a pair of Harrison/Toshiba bulbs on eBay for $110. Worked a treat! I'm looking to go to 6000K HID bulbs soon though.
My passenger bulb was randomly turning off but would come back one if I turned the lights off and back on. This went on for about a year and then finally started going off and just 2 weeks ago the bulb died. I swapped the bulbs on each side to make sure it wasn't the ballast. I just ordered 5000k D4S bulbs from XenonDepot. Hopefully they will be as good as everyone says they are. There's a $20 off code for each bulb if you buy through them so its about $100 for a set.
having your same problem at about the same time. 08 is250 with 52k miles. my left was going out, so i swapped bulbs left and right and sure enough the right started going out. that leads me to believe it was the bulb. after reading multiple reviews and opinions here on CL i went with xenon depot for bulbs. I thought about just getting a single new phillips bulb for like $70 shipped but i was worried about color differences in a brand new bulb from one with 50k miles on it already. i used the CL discount which took $40 off a pair of the xenon depot's bulbs they sell rather than phillips. i decided to go with the 6500k pair for $99 shipped for both bulbs. they shipped next day and now are 2 business days away from arrival to me.
my only concern is the color temperature... i think 6500k is as blue in color as I would be willing to go. 4300k looks good but is obviously like every other OEM hid out there. i thought maybe the 6500k would provide just a tad more hint of blue to stand out from every other vehicle with factory HIDs. we shall see...
The Xenon Depot 6500K has a slight tinge of blue but it looks white for the majority of it.
You could get the Philips Ultinon 6000K (which both Xenon Depot and Nigel-JDMParts sell) which you would pay more however it has the best lumen's output for the color in comparison to other brands.
I have pictures and video. It maybe a bit hard to tell. My Philips Ultinon 6000K is the headlights and the Xenon Depot 6500K is the fogs.
https://www.clublexus.com/forums/is-...og-2011-a.html
