Carbon Buildup fix done, now smells like burning rubber.
I was unaware that this rebuild would not fix the problem. The service guy said they installed an upgraded type of piston that would keep it from happening again. I've been reading more and it sounds like you are right, token1. What is it that I need to have done to kep this from happening? I plan on putting another 235k on this motor.
Congrats on te high mileage.
The pistons and rings will reduce the issue, but every motor, no matter how tight, has blow-by. And every modern motor, has a positive crank case vent system. The TSB did not alter the PCV system, the intake manifold (they call it the surge tank now...) is always drawing vacuum through the crank-case picking up vapors, be it blow-by, or evaporated/vaporized oil from the splashing, heat, pressure etc. I find it hard to believe the TSB is a total fix. It surely reduces how "messy" the PCV system may have been, but the key word is reduces, not fixes. I respect the engineering Toyota has, but the bolt-on catch can kit isn't much money for the insurance it won't happen again, and is a steal of a deal for those that do not have the TSB done yet and are nearing their 9 year deadline.
Plus, after seeing my engine disassembled into pieces, I don't plan on keeping this car past the warranty period. I fully trust the technicians and everything, but there's just too many pieces that got disassembled and put back together. When your talking about a motor, even the slightest errors can cause big issues later, IMO.
I personally wouldn't, just because there is a warranty that covers the issue and i'm not sure if installing an oil catch can would cause issues with that later.
Diffidently a lot of Murphy's Law flirted with having that much work done by the dealerships, or anyone for that matter. I looked at it as a plus though, basically have a refreshed motor. The bolt on catch can fix I'm using has me a lot less worried about putting miles on the car even when it reaches the post TSB 9 year deadline. The new IS250s that are not applicable to the TSB as they come from the factory with the new internals should use a catch can solution right away, as they are not covered at all once their warranty is passed.
Looking at the carbon buildup on the valves, even if one does not get the MIL/CEL/DTS symptoms, one is still loosing VE, MPGs and power due to buildup causing air flow restrictions in the area-- worse yet I can imagine all the valves have a different extent of buildup over time--- what does that mean? un-even air fuel ratios in each of the cylinders!!! One cylinder might be running 13.5:1 all the time, while another 15.2:1 etc- power robbing, EGT raising, cat wearing, gas in oil causing suckyness right there!! After the IS250 was bought, I didn't drive it hardly at all until the bolt on kit was in and installed. I want expected reliability, power and MPGs!
97 LS400
08-11-05 09:45 PM
