IS350 vibrated briefly when stops, very random occurence
Old 03-01-13, 03:22 PM
stlgrym3
stlgrym3's Avatar
Default IS350 vibrated briefly when stops, very random occurence
noticed this two days ago. not sure if related, but i just had my oil changed at the dealer a week ago. anyways, when i'm at a stop light, the car would vibrate (very subtly) for 1-2 seconds and then back to normal. i would take it in to dealer except it does not happen regularly, so the chance they'll reproduce the symptom is very low. any suggestion on why caused this random subtle vibration?
Old 03-01-13, 03:33 PM
Nikon
Nikon's Avatar
might wanna check out the carbon build-up threads.
Old 03-01-13, 03:35 PM
stlgrym3
stlgrym3's Avatar
isn't that only apply to IS250?
Old 03-01-13, 03:48 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yes, it does not apply to the IS350.
Jeff
Old 03-01-13, 04:09 PM
ISmak4
ISmak4's Avatar
According to the dealerships it's both the IS250 and IS350, at least that what it says on their computers. I believe it's a much higher chance that it effects IS250's compared to the IS350's though.
Old 03-01-13, 04:22 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
No it doesn't. It only applies to the IS250. According to the dealerships as well it only applies to the 2006-2010 IS250 and 2006 GS300.
Jeff
Old 03-01-13, 07:24 PM
edgeucated
edgeucated's Avatar
My car does that too! Exact same symptoms you described, vibrates ever so slightly as im at a stoplight. I have always suspected it was due to carbon buildup but i have never been able to prove it. I know that the is350 is not suppose to suffer from it, but could there be a miniscule amount of carbon being built up?
I have started to add techron injector cleaner every 5k miles for the last 20k miles; it doesn't seem to have any effect. My next step i plan on trying is to seafoam my car, but i haven't had the time yet, nor the knowledge.
Old 03-01-13, 11:24 PM
Fjaw
Fjaw's Avatar
Happened to me few times but I think it's because when my foot was on the brake I would accidentally step on the gas base on how my foot was positioned and causes a small vibration.
Old 03-01-13, 11:45 PM
TripleOcho
TripleOcho's Avatar
I had a Honda and this happened. turned out I had a pretty major oil leak.
Old 03-02-13, 12:16 AM
ISmak4
ISmak4's Avatar
Jeff
Really? Maybe it's different for where you live... I'm in Canada, and they showed me me on their computer and it says IS250 and IS350, I was pretty surprised that they said IS350 I even asked the service manager and a technician and they said both cars have this problem.
Nevertheless OP, just call the dealership and describe the problem you're feeling and they'll probably tell you to book an appointment and get it checked out.
Old 03-02-13, 07:34 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I work at a dealership in Canada.
Jeff
Old 03-02-13, 09:03 AM
Corbio
Corbio's Avatar
Maybe it could be the MAF sensor that needs cleaning?
Old 03-02-13, 09:41 AM
D.Jobin
D.Jobin's Avatar
You might be having the misfire issue. I think there's a new TSB on it.
Old 03-18-13, 03:35 PM
stlgrym3
stlgrym3's Avatar
this random occurrence has increased in frequency recently. i scheduled an dealer visit later this week. the SA told me they're going to run a series of mis-fire tests but told me the test was really designed for IS250 and GS300s. i saw someone brought up it could be a fuel pump issue, any other suggestions before i bring her in?
Old 03-18-13, 04:03 PM
Gville350
Gville350's Avatar
I have read about 1 maybe 2 2IS fuel pump failures in the boards here in the past year.
Quick Reply: IS350 vibrated briefly when stops, very random occurence
