CEL P0335, CHECK VSC lights are on....PLZ HELP!!!!
my car was hit in the back at work in the parking lot. nothing was damage buh u can see the 2 screws that holds the license plate on a front of the car from up close. anyways whoever hit it must have hit it pretty hard for the alarm to set off and drained out my new battery. got it jumped and now my CEL code P0355,"CHECK VSC" are on and my AFS headlights arent working. my car has 60,300 miles n its a 2007 IS350....PLZ HELP
same thing happen to me. Needed a new battery due to a defective cell in the battery. The CEL came on with po0355 code. Replaced the battery under warranty and the code went away. To reset the ecu.. you need to remove the negative plug on the battery for 20mins and put it back on.
kim0217
10-30-15 04:02 AM
pbonck
RX - 1st Gen (1999-2003)
11-07-11 12:47 PM
94esjag
10-27-09 12:06 PM
