+10mm Spacer on FSport wheel
I wonder anyone ever run 10mm spacers on your FSport 19" Wheels?
I wanna get 19x9 +30 with 255/35/19 without any fender mod at all.
Is this possible? Please give me your comment. Thanks
So you are looking to run a 255/35/19 front and rear?
Are you lowered? Pretty sure that is not going to work out in the front... I am not the expert, but it just doesn't seem like it would work without some fender mods.
Thank you both, helpers.
For info:
I did lower my car with springs about 1" front and rear.
Front tires will be 235/35/19 with 19x8+40 FSport wheels.
Rear tires will be 255/35/19 with 19x9+40 FSport wheels.
149MAX, I did extensive search and your car inspires me. My concern is I don't want to do any fender modifications. Based on your direct experience, what would be the widest spacer to put on rear with Fsport +255/35/19?
I know you run 275/30/19 Michelin PSS in the rear which is much fatter tire. But I guess that, with 275/30/19 + 15mm spacer +slam, you must have your rear fender rolled.
Will I be able to get away with 10mm spacer with 255/35/19 without having to roll the fender?
Thank you so much for your advice.
For info:
iceache925
06-05-21 08:06 AM
SCWB
12-26-10 05:18 PM
