ECT power switch back light ?
It is definitely supposed to light up. There is a bulb in there, and the wiring diagram shows wiring for the illumination, even on 2006. Unless the wiring diagram is lying. My 2011 lit up, and multiple people are saying their 07 does. Maybe pull out the switch, check the bulb (there will be a bulb), and see if there is wiring for it.
As for the P R N... bulb, it is a small #74 bulb, Lexus doesn't list it separately for the 2IS, however I believe part number 90981-11018 should be correct.
Jeff
Jeff
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20170610_114949_e8b483b85731a8ada0eb924bd6a865b9a0b37e59.jpg)
I believe 2007 was the year it started having a backlight but I could be wrong, if so someone please correct me.
If they do need to do repairs, the dash wouldn't have to be taken apart to access the switch. It's pretty simple and shouldn't take too long. They pretty much just pop right out.
