curb rash fix
Old 03-07-13, 06:49 PM
inked13
inked13's Avatar
Default curb rash fix
Whats up CL,
Just wanted to post up some pics of my curb rash repair.
The damage was on the front passenger side wheel.
This is is my first attempt at fixing a damaged part such as this an i gotta say the results are better than i expected.
What do you guys think?
Btw, I spent the last week searching for the oem touch up paint for the wheels but had no luck
but anyway I think the color match on the wheel looks pretty good.
Here she is freshly washed enjoy-
wheel before repair
wheel after repair
smoked tail lights
Old 03-07-13, 06:55 PM
Griiix
Griiix's Avatar
could you PLEASE tell me how you did it?
i have a minor rash on my rim too and its KILLING MEEEEEEEEEEEE!!
plz
Old 03-07-13, 07:10 PM
inked13
inked13's Avatar
plz
hi Griiix,
I'm glad i figured out how to do this because it was buggin me, especially since I've only had the car for a month lol
Well anyway I went to home depot and picked up a steel stick by JB weld,(i guess it would compare to body filler for different types of metals) strong and durable.
the stuff is pretty easy to use just cut a good amount of the stick that you would need and spot fill the damaged area (after cleaning and sanding)....let it dry, sand to a smooth even surface and then paint
hope that helps
Old 03-07-13, 07:20 PM
Dawa
Dawa's Avatar
good job, guy
Old 03-07-13, 07:37 PM
inked13
inked13's Avatar
Originally Posted by ProperD
good job, guy
thanks man
Old 03-07-13, 07:47 PM
FordGT08
FordGT08's Avatar
Looks really good. I've been debating on taking mine to a wheel repair shop.
Old 03-07-13, 07:48 PM
istundra
istundra's Avatar
what did you use for paint? color?
Old 03-07-13, 08:06 PM
Griiix
Griiix's Avatar
^^^^ +1
what did u use to paint/ #grit sandpaper?
Old 03-07-13, 08:42 PM
671gs
671gs's Avatar
Definitely did a good job...step by step DIY would be great!
Old 03-07-13, 09:39 PM
Jason76722
Jason76722's Avatar
Nice DIY where i can get paint? Autozone TOYOTA LEXUS?
Old 03-07-13, 10:14 PM
inked13
inked13's Avatar
its pretty easy to do on your own if the damage is not too bad
all in all this project only cost me $16
Old 03-07-13, 10:17 PM
inked13
inked13's Avatar
ill double check to be sure but its grey metallic from the duplicolor perfect match.
the match is just a hair darker than oem so if you can find one a little lighter you'd be good
Old 03-07-13, 10:20 PM
inked13
inked13's Avatar
^^^^ +1
grey metallic perfect match from duplicolor
the gash in my wheel was semi deep but i used 60 grit to get rid of any high protruding metal flakes
then straight to 400 grit (wet sand during both process)
Old 03-07-13, 10:22 PM
inked13
inked13's Avatar
thanks, yeah a DIY would be great....almost makes me wanna hit a curb purposely lol kidding
im sure there will be more curb related incidents to come so ill make sure to do one next time
Old 03-07-13, 10:26 PM
inked13
inked13's Avatar
paint supply is very limited out here on guam
but i picked up the paint at the local NAPA paint shop
they happen to be the only shop here that supplies duplicolor
on the duplicolor website theres a list of places to get the paint and autozone is there
hope that helps
Quick Reply: curb rash fix
