Top Tier Gas
Top Tier Gas
If this was discussed in the past,please excuse me.I'm on this forum now for a week or so.
I use Shell 93 octane on my Wife's new IS-250-AWD. It seems to be a good match for the engine. Does anyone get great performance from any other brand of fuel? I see that Lexus recommends 91 octane, but has anyone tried mid grade 89 octane?
I realize it's probably not good for the knock sensor to use regular 87 octane.
Just wondering.
Just wondering.
I've used 89 and 91 - no real difference.
Reality is cars these days can adjust for higher/lower octanes. There's a recommended use for many but you can generally use whatever you feel is best (ie. willing to pay for).
Also - there is a long thread in here somewhere where this is discussed at length. I can tell you I know someone who has a Mazda CX-9 (?) and it required premium. This person did not use it and after about 100 miles on the tank the car broke down. Now, that's just an example from Mazda - I do NOT believe that Toyota/Lexus makes engines that act in that manner for not using the same octane. I've driven over 1,000 miles 89 and didn't have a problem ('11 IS350 AWD).
EDIT:
I should also mention that a majority of the time I do fill up with 91.
EDIT:
The following 3 users liked this post by bob4256:
Parrokeete (07-08-22)
Just wondering.
Just wondering.
Only 91 octane. If I stay with one brand too long, I notice MPG going down a little, after I switch to a different brand, it goes back up. I alternate between Shell and Chevron.
Do what the factory recommends. The engine is tuned to run on 91. Lower octane means reduced efficiency and reduced performance. I once tried 89 and the car ran noticably slower and got worse mpg's- a waste of savings at the pump. Plus, with the 250's tendacy to have clogged injectors, you want the best firing and cleaning in there as possible.
Thanks all. I'll stick with the Shell 93.It's only 25 cents more per gallon than regular here.
GiantsFan I kind of figured you were an SF Giants fan seeing that you're in Cali.
My Bro-in-Law who moved from NY to San Fran is a traitor now.He said he likes the Giants instead of his once loved Mets. LOL
I'm a Yanks fan luckily.
https://www.clublexus.com/forums/is-...gas-is250.html
