The Oil Catch Can Experiment
Old 03-23-17, 07:17 AM
  #151
smitty2919
smitty2919's Avatar
I've seen 3 port versions...but never messed with them. I have an Elite Engineering 2 port can being delivered today and plan to custom mount it this weekend.
Old 04-07-17, 02:45 PM
  #152
Aspect
Aspect's Avatar
for everyone who has already installed their oil catch can, can anyone tell me what size hoses and couplings I need? Is the original PCV hose 1/2 or 3/8ths? My Mishimoto OCC comes with 1/2" fittings but I'm not sure the the oriiginal PCV valve and PCV hose are 1/2" as well. Can anyone confirm for me?
Thanks
Old 04-08-17, 04:13 PM
  #153
smitty2919
smitty2919's Avatar
OEM hoses are 3/8". MOST cans have 3/8" threaded holes for a simple 3/8" npt to 3/8" barb brass fitting. You will need to step the 1/2" down to 3/8"
The following 2 users liked this post by smitty2919:
Aspect (04-08-17), jcgeorge (09-19-20)
Old 04-08-17, 04:22 PM
  #154
Aspect
Aspect's Avatar
Thanks for the clarification. for simplicity sake I think I'll try to find 3/8ths fittings for the can instead. Otherwise from the original PCV hose I would need an adapter 3/8 to 1/2 which is fine but would be redundant for the other side which is just a hose from the can to the PCV valve I would need to sever it somewhere and create another adapter. This learning process has made this 20-30min job much longer than I would've thought. Still need to find someone to cut some metal for me to make the bracket fit. Wish this can came with vehicle specific brackets to make life easier.
Old 04-08-17, 04:56 PM
  #155
smitty2919
smitty2919's Avatar
Yup...I made an Elite Engineering can work on my wifes car. Custom made bracket and bought some 3/8" fuel line from autozone. Took me half a day once I knew where I wanted the can and what existing bolt to ise as a mount.
Old 04-10-17, 11:18 AM
  #156
ewingli
ewingli's Avatar
Can anyone confirm the hoses included in this will fit? https://www.aliexpress.com/item/Free...2-27c2a9dd7d30
Old 04-10-17, 04:08 PM
  #157
bazzle01
bazzle01's Avatar
10mm is 3/8"
6mm is 1/4"
Old 04-12-17, 01:27 PM
  #158
XSV
XSV's Avatar
zip ties
/problem
Old 04-12-17, 01:39 PM
  #159
Aspect
Aspect's Avatar
Originally Posted by XSV
zip ties
/problem
Yeah great solution... If you want it to look like s***. Commenting like everything is plain obvious isn't helping anyone.
Old 04-12-17, 05:36 PM
  #160
smitty2919
smitty2919's Avatar
Here is my setup:
I'm using an existing bolt that holds the overflow tank to the fan shroud Made this from one piece of 2" angle iron cut up and re-welded. Picked up 3/8" fuel line from autozone.
With the well known issue of carbon buildup on these cars combined with their "sporty" nature, I'm surprised no one offers a bolt on kit...at least I didn't find one.
Aspect (04-12-17)
Old 04-12-17, 06:12 PM
  #161
Aspect
Aspect's Avatar
Here is my setup:
That looks really clean! Nice job!
Old 04-12-17, 06:18 PM
  #162
XSV
XSV's Avatar
Looks fine to me. Not sure why u mad tho?
Who is looking in your engine bay anyway?
Old 04-12-17, 06:59 PM
  #163
Aspect
Aspect's Avatar
Hm, I suppose I owe you an apology as I honestly thought you were trolling me given your response to my other post in the sway bar thread about using a breaker bar. That doesn't look that bad actually. I rejected the idea of just zip tying it since it's almost $200, and I live the principle of not cheaping out on things when I've already invested into something. I have the same can so is it actually just zip tied using the supplied bracket holes? I figured it would need a full on metal bracket given it's weight.
Old 04-12-17, 07:04 PM
  #164
XSV
XSV's Avatar
I just looped a small zip tie through the bracket holes and then looped a bigger zip tie into the small loop and around the hose that is running in the picture. It's slightly sitting on a hose underneath so the entire weight isn't hanging on the zip ties alone. And then I just did the same process around the body just to make it a bit more sturdy. It's not ideal but gets the job done.
Aspect (04-12-17)
Old 04-13-17, 05:19 PM
  #165
Cole2is
Cole2is's Avatar
I just recieved a mishimoto catch can and I had ordered the large size (7" I believe) and its huge! Does anyone know if it would even fit i am also confused because it only came with one hose.
Quick Reply: The Oil Catch Can Experiment
