Dome light not turning on
Has anyone had this problem my interior dome light, visor mirror light, puddle lights aren't turning on.
Also when I fill up it takes a while for it to show that it's full
Does any one know a solution?
Thank you in advance!!
I had the same problem after installing LEDs all over. Check the fuse box by the battery it should be fuse number 9 if i'm not mistaking. That's the fuse that burned out on me.
http://drivers.lexus.com/t3Portal/do.../sec_04_03.pdf (page 331)
oh man you burnt your wiring up! jk but i think the fuse is under the hood, should say like dome.. maybe a 15A fuse. swap one from like the horn real quick or any other known good fuse and place it into the dome one and see what happens. its also possible you got some bad LEDs
