Size of Projector Lense?
Old 03-19-13, 08:32 AM
pmanliu
pmanliu's Avatar
Default Size of Projector Lense?
Will embark on a headlight journey soon (once i can find a decent set of used headlights) and was planning on swapping out the OEM lense with a clear lense (http://www.theretrofitsource.com/pro...roducts_id=134). I had a FX-R lense on my previous car and the cutoff lines, light output, and look was amazing. Looking to do the same in the IS.
Does anyone know what size lense the IS uses or can provide pictures of the headlight disassembled? Trying to confirm if lenses from theretrofit source will work on our vehicles.
Thanks,
Pat
Sample of new cutoff line:
Edit: looks this this individual has tackled this already and compiled a pretty detailed write up: http://www.jvxdriver.com/is250_retro.htm
Old 03-19-13, 09:14 AM
ohiois350
ohiois350's Avatar
Some member here done the STI-R lens before (3") it give a little clear look a little improvement, but not near or close to JVX on planet hid did the hybrid with rx350 rear projectors, hope it help
Old 03-19-13, 09:53 AM
kwik801
kwik801's Avatar
Correct. It is the STI-R. Look on the first page and you can see the before/after
https://www.clublexus.com/forums/is-...ld-thread.html
Old 03-19-13, 10:56 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I had STi-R lenses in my older headlights. They aren't bad.
Jeff
Old 03-19-13, 11:33 AM
kumquatism
kumquatism's Avatar
Totally recommend getting a clear lens. The cutoff is gorgeous. I always stare at my lines when I turn my headlights on. The stock projector uses a 3" lens.
Zeke21
SC- 1st Gen (1992-2000)
14
01-09-14 04:54 AM
94LEXUS400
03-26-11 04:23 PM
blacksc4
11-23-10 04:13 PM
Top Hat
GS - 1st Gen (1993-1997)
120
05-17-09 01:26 AM
Jmai22
14
05-01-03 08:39 PM
Quick Reply: Size of Projector Lense?
