About to install GFX front lip
Old 04-01-13, 12:15 PM
jbone29
jbone29's Avatar
Default About to install GFX front lip
Is double side 3M tape needed or can i just use the screws from the stock lip and be done with it. I viewed the DIY thread on this but want to double check with people who have installed them.
Old 04-01-13, 02:28 PM
Gville350
Gville350's Avatar
I purchased my GFX front lip used and I just installed mine using the stock bolts and latches. No tape needed, but if you don't like to see sunlight between the bumper and the lip, then the tape will more than likely be needed around the area below the foglight curved portion.
Easy install might I add!
Old 04-01-13, 02:51 PM
jbone29
jbone29's Avatar
thanks for the reply.
Old 04-01-13, 11:16 PM
davyjordi
davyjordi's Avatar
i did the same as the poster above - just used the bolts and latches that were stock and have had no problems. the lip has been on the car for some two years now.
n8236
09-06-11 04:05 AM
HeartmyIS
01-13-10 05:12 PM
iSpeed250
12-24-09 01:42 PM
LaosXpress
02-16-09 04:15 PM
EthanV
10-24-08 10:06 PM
Quick Reply: About to install GFX front lip
