Wheel bearing going bad or something else
Anyone have idea what this could be? I hear a hum/whirling noise when I drive, I can hear it the most up to 40mph and all the way down to stoping. i think it's the bearings because I just put new tires on less then 1k miles (nitto 555- 35series) on 19" works. Here are other things i noticed. when I slow down to less then 5mph, the car jerks/bounces real slightly. I also just installed bc coils same time as tires. Any ideas?
If it is a wheel bearing that is not as bad as it may seem. The wheel bearing and the complete hub unbolt and rebolt as a entire assembly.
Do you have aftermarket wheels? If so, one of your hubcentric rings may have come off without you noticing. It could be a torque issue with the lugnuts. It also could be a wheel/tire that is out of balance.
If its a bearing then it will be almost a pulsating sound, on and off. If you suspect it's just one side try turning in that direction and away from it and take note of the sound. If it gets worse its the opposite side of the side you're turning towards if that makes any sense. Usually they don't go bad too quickly unless there was some sort of impact.
As for the jerk/ bounce of the suspension, id go double check to make sure all bolts are tight
highmiles
05-24-05 10:15 AM
