Mark Levinson Sub Repair Kit
Has anyone used the subwoofer repair kit for the IS? I know people have used it for the GS and it has worked great for them. This could be a cheap fix if it works. Here is a link of the sub repair kit...
http://www.simplyspeakers.com/toyota...8m-toyota.html
thanks
thanks
this is just a new surround. if the subwoofer is blown its the voice coil thats no good, having a new surround will not fix it. best bet is to find a member like myself who has upgraded subwoofers and buy there stock. assuming they kept it and didn't throw it out like i did...
You don't even need that see my post below, they just jumped the spider with a new wire and its good as new. Not sure why you assume the voice coil is bad, thats quite a hard thing to mess up unless you are severely overpowering the coil.
https://www.clublexus.com/forums/is-...ml#post7742308
This might be what I need. thx for the info, OP.
I will try the even cheaper solution first tho - just using silicon and seal up the edge where it tears. I just have been busy and did not have the time to remove the back seats to access the subwoofer.
Discobee
10-14-16 02:32 PM
300, 862800w101, auto, coil, disassemble, es, gasket, levinson, lexus, mark, marklevinson, marklevison, reair, remove, repair, subwoofer, voice
