Broke lug nut key
So I tried putting my summer wheels on today. I got both on my passenger side then when I went to the driver side the factory lug nut key broke. I went to the dealer and got another key and that one broke as well! What should I do now?
Yea its the factory locking lug nut key. This is the first time I've taken off my factory wheels on this car. I think I'm gonna make an appointment at the dealership to have them taken off cause I don't wanna keep breaking keys.
Are you taking the locking lugs off, or putting them on? If you're putting them on, don't. As Gville350 mentioned, the factory lugs and locks are not meant to be used with aftermarket wheels.
If you're taking them off, could it be possible that the locking lug has seized onto the stud? Just throwing it out there.
DIY fix... Find a double hex socket that just almost fits onto the lock lug nut then pound it on with a hammer, then proceed to take it off with a ratchet or impact if you've got it. the double hexs' points will grind into the outside of the smooth lug nut and bite enough so you can take it off. Also if you have a bench vice you can then pound the lug out of the socket head and re use both, I've done this on my Lexus, my dads Lexus, and my moms Toyota, the keys seems to be pretty crappy when it comes to over tightened nuts... I avoid it now since I bought a gorilla lock nut set for my oem wheels.
I'm assuming the pattern on the key is possibly stripped?
Last edited by medic250; 04-17-13 at 07:27 PM. Reason: Almost is better than barely ;)
