If it came with it installed you will have to remove the inter carpet of the trunk to get to the screws. Once you remove the screws use a microfiber towel to separate the mounting tape from the trunk very easy to do.
Yes remove the liner and I think theres 3-4 screws that need to be removed But why are you taking it off, Are you aware that you will have holes in in the trunk if you don't put anything there.
