dvd nav updates
how do I update the DVD? I keep clicking eject and it says "no dvd inserted" does this mean that there is no dvd in the stock system?
Posted from ClubLexus.com App for Android
After a while it will be 'sucked' back into the nav and it will allow you to use it.
Originally Posted by vapid2323
Did you remove the panel so the DVD can be removed? Its behind the digital clock.
Just do a search, if I was able to do it I am sure you can figure it out.
Super Moderator
Originally Posted by Bichon
Quote:
Originally Posted by NYG
I wasnt aware the panel needs to be removed for this. is there ny other way to have it done?
I'm not sure why you weren't aware. I told you so in the earlier post you made on this subject: https://www.clublexus.com/forums/is-s...questions.html
Super Moderator
sorry I never read your reply (forgot to sub to the thread). So there is a pin in the trunk to only remove the face behind the clock? or to remove the entire panel? Seems like overkill/very inconvenient to me if you have to remove the entire panel face to get to a nav dvd.
Two pins. Should be in a pouch in the toolkit. Insert both pins tools in the small holes all the way; they push the clips that hold the panel in place out of the way. With the pins inserted, the panel comes right off.
thanks. so I dont have to do the whole series of steps involved in the video posted above?
Just go out to the car and try, sometimes it's far quicker to just try instead of asking the same questions over and over
