Can I install springs alone?
I was planning on installing my springs myself since I have all the required tools but was just curious if I could do it alone or would need another person to help me? My main concern is having enough force to get the lower control arm aligned with the spindle(hub).
One at a time will work. That's how I did it when I installed my F Sport springs. Take your time and be careful. You will be fine. Make sure you get accurate torque specs so that you put everything back together properly and you're good.
if you get stuck, just follow these instructions, it also has the torque specs for each bolt/nut
http://is.sewellparts.com/pdf/PTR0753080.pdf
Rears are the same, fronts have one minor difference where the strut connects to the LCA. I would remove the bolt holding the strut to the metal "C" piece that connects to the LCA. Might be hard to imagine but you'll understand once you start taking apart the car.
AWD Front Strut:
RWD Front Strut:
AWD Front Strut:
RWD Front Strut:
Rickster31
Suspension and Brakes
12
07-21-07 09:55 PM
Kendhal
03-09-04 06:16 AM
