footwell led help
I am trying to get some footwell led strips from vled. However what all do I need with them? I saw the website had bunch of options. Thanks for the help
What are you trying to wire? Are you tapping into the footwell lights that are already there, or are you using an alternate power source so you can control when they are off and on?
If you're tapping into the current lights, then you just need the LEDs and maybe some wire so you can run your grounds.
If you're doing a different power source, you'd need a switch to turn them on and off, and much more wire.
Also, I recommend getting some tape. The tape on the VLEDs were pretty bad. They fell off within a couple days for me.
