Replacement headlamps and fogs
Hello. I am wanting to replace the factory head lamps and fogs on my 2007 IS 250. I want to black out the head lamps and get the lights that have that bluish color (I'm sorry for noobness, idk what it is called) and I want some cool fog lights! Any suggestions?
The lights that your looking for are called HIDs The bluish color that you want is either 6K or 8K. If you search, there are tons of HID threads here to give you ideas.
As for blacking out the headlights, you can either do it yourself by baking them in the oven to open them up, or buy the 2011-2013 LED headlights that already come with the inside housing painted black. Again, another search will yield you with more info
The higher "K" the more blue/purple/pink the lights will be but you will have less usable light. OEM HIDs are 4100K and they will give you the most usable light.
And yes you can put any color lights that you want.
6K is white with a hint of blue, and 8K is the same but more blue
lexusplz
04-13-21 11:12 AM
