I have some questions on the 2012 headlights
Old 05-11-13, 09:20 PM
RobzKar
RobzKar's Avatar
Default I have some questions on the 2012 headlights
I know I'll probably get schooled on this but I just did the 2012 conversion on my 2006 IS an I have a question for the knowledgeable gurus up in here.
1- how do you get the LEDs to run as your DRL's when you turn on ignition because right now my LEDs only turn on when I turn the parking lights on.
2- for the mean time if I don't have a knowledgeable dealership that does not know how to disable the DRL's can I just remove the fuse? And will that have a negative affect if I leave it like that other than not being able to turn hi beams on.
Thanks in advance.
Old 05-11-13, 09:35 PM
RVCAis250
RVCAis250's Avatar
The answers to both your questions deal with rewiring. You need the LED strip to be rewired to the DRL feature which will also disable your DRL bulb. If you're in SoCal, hit up Tommy @ MusicBox and he can do it for you.
Old 05-11-13, 10:56 PM
CalitriSC
CalitriSC's Avatar
It takes the dealership like 5min to turn off the DRLs. For my LEDs I just leave the lights on the first setting so it stays on when the car is on, I didn't want to to any wiring. They shut off anyway when you turn off the car.
Old 05-11-13, 11:22 PM
RobzKar
RobzKar's Avatar
Thanks for the info. Is there really no DIY on it, I live in central Cali and would like to do it my self if possible due to my car being apart right now on a rebuild but also the distance. If any one can please help I would really appreciate it. Thanks again
Old 05-11-13, 11:24 PM
RobzKar
RobzKar's Avatar
You mean your parking lights correct??
Old 05-11-13, 11:35 PM
RobzKar
RobzKar's Avatar
Old 05-11-13, 11:36 PM
whitebeast
whitebeast's Avatar
to disable DRL, you need techstream mini VCI ODB2
shodoc
NX - 1st Gen (2015-2021)
01-21-18 04:23 PM
SLMis
07-08-16 03:45 PM
rcJten
RC F (2015-present)
07-05-16 07:02 AM
GreggyG
GX - 1st Gen (2003-2009)
05-12-14 08:11 AM
jgarrido
03-03-12 10:36 AM
Quick Reply: I have some questions on the 2012 headlights
