HELP, who else here has or had the Vortech supercharger ??
Hey, I recently bought a Vortech supercharger and I managed to get everything to fit in but on the last bit. I was given an identical water pump pulley that suited our original one on the motor. Problem is, when I put the two water pump pulleys together it doesn't line up with the SC pulley so one is facing the radiator more while the other is closer to the engine. If somebody can help me with this then it will be appreciated
Well I received an water pulley pump and there's only once place for it to go. The pulley is like a cup with one side flat with holes in it if you get what I mean ? and to me i would of thought that you would put the two flat side next to each other then bolt it up. But when you do that, it doesn't line up with the SC pulley. Therefore if you turn it the other way then it seems alright. But was not sure if this is exactly what you're meant to do....
You're going to need to do whatever ensures your crank pulley, water, alt, etc pulley line up first. THEN, you will need to take whatever practical means necessary to ensure you get your blower pulley lined up with that stuff. You may need to shim it or add in billet spacers. Whatever you do it needs to be near perfect or you'll walk the belt and shut down your car..
For this reason (among many others) I dislike setups that tie right into the engine belt loop. I could get you a 2nd crank pulley that would spin the Vortech and nothing else. Alignment is much easier and precise when you only need be concerned w a piggyback crank pulley and blower pulley.
Check out my Rotrex:
![](https://imageshack.us/scaled/landing/248/imageqdn.jpg)
ozzy250
05-28-13 11:14 AM
