Advice on an accident
hi all,
thanks for all the advice, underneath is not damaged i suppose as i still can start the engine and drive normally. perhaps a new hood and bumper? headlights i dont think they are dmg. so would be under 1k? thats quite a relief to hear, as this is my first time encountering such an incident
Replace hood, paint hood, replace hood hinges, replace grille, replace left headlamp tabs are broken most likely. Possibly rad support may be damaged based on the depth of the dent. Blend both fenders to color match with new hood, bumper has a deep scratch will require 1 hour repair and paint. Plus labor to Install hood. remove and install bumper to assist with repair, aim headlights etc. your looking at 2800+ usd I'm an estimator
Looks like you ran under a truck or higher vehicle.?��
Seems legit, and if you're in Singapore like previously stated, the currency exchange is nearly 1:1. I think 1USD is equal to 1.25 SGD, i just got back from there and it was nice not to have to multiply in your head while drinking at the bar. There's also no minimum wage i believe so I'm not sure if that will affect your labor costs.
-USNsaint71
-USNsaint71
-USNsaint71
I'm sure parts are a lot more expensive there too if that is the case....
andrew18
SC- 1st Gen (1992-2000)
13
05-17-09 05:45 AM
