Airbag light
The other day when i turned my car on it went through all its normal checks and said check completed (thus all the dash lights went out) however the airbag light stayed on.. its a light on the top right side of the dash (person sitting with a seat belt on and airbag in their face).. Anyone have any idea what this light could mean?! I'm assuming it has something to do with the airbag but i just don't understand why it would be on?! Nothing has changed in my car.. i didn't hit anything or anything like that.. Could this be a sensor gone bad or something?! any help would be appreciated..
2008 Lexus is250
2008 Lexus is250
Could be a number of things. You should have it checked to be on the safe side. The airbag module, and airbag itself, one of your sensors or even just a short in the wiring could cause the light to come on. Try a reset by disconnecting the battery for a couple minutes and see if it goes away. If so and then it comes back on, you definitely want to have it looked at.
Been discussed every now and then:
Check it out: https://www.clublexus.com/forums/is-...ution-tsb.html
Mine comes on and off randomly. It has been off for a while now but who knows when it will come back on.
