Will I rub?? Want to purchase 19's lowered on H&Rs...
05-30-13 | 06:09 PM
I was looking into getting the Stance SC6 in 19's
http://www.oemconcept.com/images/Sta...chined%202.jpg
I am planning on getting the staggered set, which come in 19x8.5 and 19x9.5.
Would I need to modify my fender at all to make these fit? I am lowered on H&R's/F-sport shocks.
Also, would tire sizes would you recommend? Does the size of the tire make a difference in the ride quality?
Thanks
V
05-30-13 | 07:14 PM
Prob not, but always test fit ...
05-30-13 | 07:17 PM
Only problem is I'm planning on buying the set online...
05-30-13 | 07:38 PM
05-30-13 | 11:51 PM
depends on offsets and tire size...
05-31-13 | 12:20 AM
Quote:
Originally Posted by
GiantsFan
right.
I have 19x8.5 235-35-19 all around cuz mine is awd . NO rubbing issue at all. perfect fit. hope it help a bit
05-31-13 | 10:28 AM
Not sure what the offsets are but I'd go with a 225 up front and maybe a 265 in the rear. Most people rub the tire up front.
05-31-13 | 01:36 PM
Offset is 35 front/ 35 or 40 for rear.
05-31-13 | 08:33 PM
Vibes63
you should be fine with the sizes I gave you but I'd get the rear rolled. Unless you test fit and they're ok.
06-01-13 | 12:06 AM
225 is a safer bet. 235 you might rub slightly on the bumper tabs. which is an easy mod. so i wouldnt be concerned. looks like nice wheels though!
06-01-13 | 03:36 AM
with those offset and H&R springs...i really don't see no rubbing at all in the rear and in the front 225 will clear perfect but you may not be low enough for it to look sweet so go 235 and you may have to relocate the front bumper tabs.
06-01-13 | 10:34 AM
You will not rub...end thread.
Running the sAme setup spec wise lowered on h&rs. 235/35 up front 265/30 rear
06-01-13 | 11:07 AM
SL222 that was exactly the answer I was looking for...thank you
TNH
11-26-14 07:39 AM
jcheng
12-07-13 10:10 PM
MrBBQ
05-30-09 12:37 AM
GS3Tek
06-10-08 08:49 AM
TonY_G
04-12-07 05:19 PM
