Rim offset question
06-02-13 | 12:05 PM
Rim offset question
Does anybody know offset for theses specs 11 inch rim with zero offset with 10 mm spacer ? Thanks
06-02-13 | 12:53 PM
(offset) 0mm - (spacer size) 10mm = -10mm .
06-02-13 | 01:27 PM
offset
So the offset will be 19x11 and offset would be 10 mm?
06-02-13 | 03:31 PM
The rim size is 19x11. The offset of the rim is 0, but if you add a 10mm spacer, it'll act like the following specs : 19x11 -10mm.
06-02-13 | 03:47 PM
Which would be too a wild setup for your car.
Ls460kidd
08-07-17 10:56 AM
celm
Wheels, Tires & Brakes Forum
12-14-12 03:41 PM
yusef
02-11-08 07:15 PM
Jasono31
06-27-01 10:23 AM
