Battery died, charged, now won't start? Help please!
Ok so for whatever reason my battery died, I'm assuming I left a light on somehow but am not really sure, it's been a few days since I've driven it. So here's what I did:
1. I put a battery charger on it at 2 amps for about 4 hours (didn't disconnect the negative cable first, I'm worried this was a mistake ). Car still won't start.
2. Since it wouldn't start after (1) I put the battery charger on the highest setting for a quick start (I think 50a). All the lights are on in the car but when I push the start button, nothing happens.
3. I read in the owners manual that I was supposed to disconnect the negative cable before charging, so I disconnect the negative cable, put the battery charger on, and the charger says the battery is full. I connect the negative cable, a couple lights come on inside, I press the start button, all lights go out like it died.
I feel like I probably just blew a fuse, I was going to check them last night but it was getting late and decided to mess with it more today. Today I will have a multi-meter with me to make things easier. Just wondering if anyone out there has run into a similar issue. Thanks in advance!
The battery checking devices they have at auto parts stores put a load on the battery similar to what happens when you try and start the car, ie they are testing the voltage and amperage output of the battery.
Strlsn (11-10-23)
Push start button system is very fuzzy and so it doesn't respond well with recharging battery. Before it let the car start, it will check for votage and other parameters. If any of the condition doesn't meet with the requirement, the engine start procedure won't happen. Change a new battery, and all the problem will be gone.
I went to autozone today actually and got mine tested because when I tried to start the car it would sound like it wants to die and it said on there machine I needed a new battery so I asked them if they could replace it and they said they don't recommend Doing it there? But to go to the Lexus dealership since sometimes the battery's make the car not start and reset the ECU on the car and I would have to tow the car to Lexus. Sorry to comment about this on your thread but I was curious if this is true.
