Homelink not working?!
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I programmed my homelink just fine earlier this year when I first bought my IS. Before when you would press the button the green light would go to red and garage would open. But now when I press the button it just stays green and garage won't open. What is going on?!
If it helps, its a 2012 IS350.
I couldn't re-program it either when I got bumped to the smaller garage.
It kept blinking red when I tried to make it learn the new frequency. So I erased the memory and now the old door won't work anymore! Followed the instructions in the manual too.
So now I just carry a remote garage opener, old school style.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
I decided to try to reset my homelinks and that didn't work either. I opened my door and notice my door lights not working. And tried to use my dome lights that didn't work either. What would the chances of all those lights going out? So I looked up a wiring diagram and checked the fuses tide into the body ECU. Thought about it again and if the body ECU would down, it would throw a check engine light. Decided to check the Dome 10A fuse. Turned out that blew while I was installing my coilovers (I unplugged the rear trunk connector and it may have shorted -_-) Anyways if anyone has problems like mine where all interior lights and homelink don't work. Check the fuses! Hope it helps.
turbotuner
06-15-10 06:48 AM
