Finally got Vorsteiner (Ventross) trunk painted and on the car. I will adjust it a little for perfect fitment, this is right after bolting it on no adjustments yet. And I am still putting the other emblems back on the bottom. Very rare piece though
Well done. What did you use to black out the tail lights and the reflectors? Also, are the emblems easy to remove on the IS (are they glued on from the factory)? Love the look.
Can't speak for his tail lights but the emblems are easy to remove. Use a little goo gone on the emblems and you should be able to wedge them out. The "L" emblem on top has two pins on either side that go into holes on the trunk, but aren't fastened to anything. IIRC the "Lexus" might have one or two pins, as well as the "S" on the "ISX50" side. Hope this helps!
