Went to get the car dynoed... i think they are still new at doing dyno runs for lexus and automatics lol... since the graph is all over the place and numbers is low on first 2 pulls...
Dropped on BCR 14/12, will give it more low eventually. the roads on the 405/ Sunset blvd are too horrendous. Sadly, I pushed out the front left fender when it was slammed before i raised it which I wanted to avoid
Hello there, It rubs a little bit on dips or bumps on the road. I do not have camber kits on the car only coil overs with 14k front and 11k rear.
I’m on an offset that’s larger than yours but it rubs bad and is killing my tires sidewall. On 12k/10k though. Shouldn’t a smaller offset rub more than a larger offset? Or does the additional 2k spring rate make that much of a difference? Does your fender liner have a hole near the bumper tab already? Mine is rubbing straight on the tab already when it dips on bad roads. Any suggestions? I’m thinking of going on a lower offset hoping it will help. But geometrically based on the suspension movement it should be worse. Or am I wrong?
