Fsport exhaust uneven after installation
Old 06-08-13, 04:43 PM
patelmd
patelmd's Avatar
Default Fsport exhaust uneven after installation
Has anyone experienced one of the exhaust tip sticking out more than the other? My left tip sticks out more than the right after I installed my F-sport Exhaust. I looked to make sure all of the hangers were attached and they were. Is there something im missing or I didnt do?
Old 06-08-13, 04:58 PM
jgbackes
jgbackes's Avatar
Mine don't do that I just went outside with a ruler
I would probably loosen all of the bolts, wiggle every thing till if fit correctly then then do a final tighten. If that doesn't fix it I would call the people you bought it from.
Old 06-08-13, 05:21 PM
Hoovey689
Hoovey689's Avatar
Just fix the hanger. It's a common occurrence
Old 06-08-13, 05:23 PM
whitebeast
whitebeast's Avatar
Any mod on mid pipe?
Old 06-08-13, 07:09 PM
reyoasian
reyoasian's Avatar
play around with the hangers
Old 06-09-13, 09:54 PM
2genIS
2genIS's Avatar
did you install the exhaust by hand or air gun? if you install by air gun.. DO not use air gun to tighten the bolt.. you can you use the gun but don't tight it all the way in.. tighten by hand.. I have the same problem with the driver side sticking out more then passenger.. I went back and unbolt all the bolt and tighten by hand and is even now.. the driver side does stick out a little bit more then passenger but un-notice at all..
Old 06-16-13, 02:07 PM
patelmd
patelmd's Avatar
i tightened it by hand and adjusted the hangers, and the driver side is still sticking more out than they other.
Old 06-16-13, 07:37 PM
pmanliu
pmanliu's Avatar
How much more does it stick out? Did you try tightening the bolts evenly in a pattern?
Old 06-17-13, 06:23 AM
whitebeast
whitebeast's Avatar
Do you have pic of it?
Old 06-19-13, 01:50 AM
flexthatdx
flexthatdx's Avatar
pics would help. I would loosen the bolts and wiggle it around along with playing around with the hangers and tighten everything up
AlexWL
Performance
10-16-13 09:09 AM
Cuztom350
Performance
16
01-07-12 11:56 PM
Gs350Lola
11-15-11 08:14 AM
jv250
Performance
03-31-11 05:04 PM
stlgrym3
Performance
03-30-11 08:01 PM
Quick Reply: Fsport exhaust uneven after installation
