Need help for is-f front calipers upgrade on isX50
Old 06-18-13, 09:01 AM
TOMMYPHAM
TOMMYPHAM's Avatar
Default Need help for is-f front calipers upgrade on isX50
Hi Guys
I thinking about upgrade my front calipers . I would like to ask you a question about is-f front calipers upgrade on is250/350 with out is-f hubs bearing .
Hope someone can answer my question .
Can I just buy 2 front is-f calipers and then buy another after market BBK rotors for is250 ( will same size with is-f )
Will this setup work with out is-f front hubs bearing upgrade ( i understand is-f rotors needed upgrade with is-f front hubs bearing onis250/350 )
Hope you guys can help me
Old 06-18-13, 01:14 PM
PAVGR
PAVGR's Avatar
Originally Posted by TOMMYPHAM
Hi Guys
I ve done this 2 years ago.I bought the ISF calipers front and rears and i made in a workshop slotted rotors so that i dont have to use ISF hubs.It costs a little bit more but you dont have to buy the ISF hubs so....
I hope i helped you
Old 06-18-13, 01:23 PM
PAVGR
PAVGR's Avatar
Found this closer pic
Old 06-18-13, 03:39 PM
Gville350
Gville350's Avatar
^Can you go into detail about how the rotors were "made" to fit 2IS hub and work with the IS-F caliper?
Old 06-18-13, 04:01 PM
1FlexedLex
1FlexedLex's Avatar
yes more input would be greatly appreciated.
Old 06-18-13, 06:01 PM
TOMMYPHAM
TOMMYPHAM's Avatar
Yes . More info please .
Old 06-18-13, 09:09 PM
PAVGR
PAVGR's Avatar
I just bought the rotors(mine are from a BMW ,same diametre as ISF ).You can buy the rotors from another car(as long they have the same width and everything,much cheaper) and then have a work shop cut the midle ,make aluminium plates and adjust them (by puting the ISF calipers on your car and measure )on your hubs.It is very easy if you have a good work shop do this for you and you can have the rotors done as you want them(i wanted them sloted).I m sorry for my english i hope i helped.You can ask me anything else if i can help
Old 06-18-13, 09:25 PM
PAVGR
PAVGR's Avatar
I just bought the rotors(mine are from a BMW ,same diametre as ISF ).You can buy the rotors from another car(as long they have the same width and everything,much cheaper) and then have a work shop cut the midle ,make aluminium plates and adjust them (by puting the ISF calipers on your car and measure )on your hubs so that you dont have to change your offsets and anything else .It is very easy if you have a good work shop do this for you and you can have the rotors done as you want them(i wanted them sloted).I m sorry for my english i hope i helped.You can ask me anything else if i can help
Old 06-18-13, 11:29 PM
GiantsFan
GiantsFan's Avatar
I'd just pick up the hubs... So you know it works and won't have problems later on.
Old 06-19-13, 01:22 PM
PAVGR
PAVGR's Avatar
I thought that to but if you use ISFs hubs you directly change your offsets and i didnt want that plus i wanted slotted rotors and my brakes now are a lot lighter than ISF are.I have them for 2 years and i dont have any promlem.It s up to you guys.I hope i helped
Emprado
IS F (2008-2014)
12-24-15 06:05 AM
Imnutz4jdm
Suspension and Brakes
07-03-11 12:00 PM
PAVGR
04-14-11 05:17 PM
IS350HKS
08-12-10 12:55 AM
Brandon@TR
Wheels, Tires & Brakes Forum
03-28-08 11:21 AM
Quick Reply: Need help for is-f front calipers upgrade on isX50
